Every time I switch from my "Civil3d" workspace to "3D Modeling" and back again, all my toolbars disappear. Not the end of the world but certainly a pain in the butt. Does anyone else experience this or a have a solution?
Solved by Murph_Map. Go to Solution.
Look at the _wssettings command or if you use the CUI to edit the workspace make sure you SAVE the workspaces.
Well dont I feel like a noob. The wssettigns was set not to automatically save the changes to workspaces. Thanks for that!
Hi, I was having the same problem. I kept on losing my toolbars and now have to recreate it again. With this change in wssettings to save changes it works. Did a test run with a couple of toolbars on and no problem except when I change from one work space to my saved workspace the toolspace dialog box disappears but the Prospector in the ribbon shows it one. I have to click it off and then on for the Prospector dialog shows up to show up.
Thanks Murph, I have had this problem in the past and dealt with it in other ways, thanks for the fix.
always supporting our troops, thanks for your service
