I just upgraded to Civil3D 2014 and Windows 8. When I create a TIN surface using a DEM file no contour lines are displayed. Points are processed and triangles are created and can be displayed but no contour lines. Contour line layers are set to display in the style file. Any suggestions?
Solved by Joe-Bouza. Go to Solution.
Is it possible you went into surface level of detail and the topo is not dense for your zoom level?
Your Name
Your Name
Perhaps you have a layer turned off or frozen?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I agree with Neil, post the file so we can take a look at it, if you don't want to share it in a public place, e-mail it to me and I'll take a look at it when I can.
I have a gmail account named c3dplus if you want to share it.
How was this resolved? I am having the same issue. Surface model is fine. All layers are on, thawed and unlocked. Have tried multiple styles to no avail. In fact, contours showed up fine in this same file all day yesterday. But this morning, nothing...
Ok - update - the default Autodesk styles work at a contour interval of 2'. I need a tighter contour interval because this is very flat topography. As soon as I change it to a tighter contour interval, the lines disappear... But it worked fine yesterday...
Mark Green
Working on Civil 3D in Canada
I know it can be hard to find stuff in there. But it is in there:
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/GUID-AB4F7A73-40C4-40D6-8381-FF7E9878BC08.htm
Mark Green
