Civil 3D Forum
TIN surface won't create contour lines
12 REPLIES 12
Message 1 of 13
wolfjohn1
3665 Views, 12 Replies
I just upgraded to Civil3D 2014 and Windows 8. When I create a TIN surface using a DEM file no contour lines are displayed. Points are processed and triangles are created and can be displayed but no contour lines. Contour line layers are set to display in the style file. Any suggestions?
12 REPLIES 12
Message 2 of 13
Joe-Bouza
in reply to: wolfjohn1
Is it possible you went into surface level of detail and the topo is not dense for your zoom level?
Your Name
Your Name
Message 3 of 13
sboon
Perhaps you have a layer turned off or frozen?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 4 of 13
neilyj666
As a follow on from Joe's post - what contour spacing have you got set in the surface style - is it suitable for the topography?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 13
wolfjohn1
in reply to: neilyj666
I have tried with 10' major and 2' minor and 25' major and 5' minor contours. 2010 and 2013 process the same DEM file with no problems at both contour settings. Seems to be a problem with 2014.
Message 6 of 13
neilyj666
can you post the file(s)?
Message 7 of 13
wolfjohn1
in reply to: Joe-Bouza
Not sure what you are asking. The DEM files covers a USGS Quad that has plenty of relief. 2010 and 2013 process the file at 10' major 2' minor and 25' major and 5' minor contour intervals with no problem. I Have tried other DEM files and get the same result.
Message 8 of 13
BrianHailey
I agree with Neil, post the file so we can take a look at it, if you don't want to share it in a public place, e-mail it to me and I'll take a look at it when I can.
I have a gmail account named c3dplus if you want to share it.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 9 of 13
wolfjohn1
Thank you to all that posted. Your help is very much appreciated.
Message 10 of 13
anissa
How was this resolved? I am having the same issue. Surface model is fine. All layers are on, thawed and unlocked. Have tried multiple styles to no avail. In fact, contours showed up fine in this same file all day yesterday. But this morning, nothing...
Ok - update - the default Autodesk styles work at a contour interval of 2'. I need a tighter contour interval because this is very flat topography. As soon as I change it to a tighter contour interval, the lines disappear... But it worked fine yesterday...
Message 11 of 13
troma
in reply to: anissa
Have you checked the LEVELOFDETAIL ? (As per the post marked as the solution.)
Mark Green
Working on Civil 3D in Canada
Message 12 of 13
anissa
in reply to: troma
Thanks! That worked. It wasn't clear from the "solution" post that LEVELOFDETAIL was an actual command. And turns out there's nothing in Help about it.
Message 13 of 13
troma
in reply to: anissa
I know it can be hard to find stuff in there.  But it is in there:
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/GUID-AB4F7A73-40C4-40D6-8381-FF7E9878BC08.htm
Mark Green
Rail Community
