Civil 3D Forum
TIN surface contour color
5 REPLIES 5
2616 Views, 5 Replies
I have TIN surface. And I have set contour color by layer. If "Elevation" setting are turned off surface countors are by layer. If "Elevation" setting are on, contours becames of color set in color scheme. I have attached images of it.
Can I keep my contour colors by layer if I turn "Elevation" setting on?
5 REPLIES 5
johngordon6189
Elevations refer to the Elevation Analysis, and the colors are dependent on how you set up the analysis. Your contours are controlled by the major and minor contour display settings.
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
in reply to: johngordon6189
In image TIN_1.png I want to have black contours. How can I do it? My major and minor contour are set bylayer and my layer are black, but my contours are not black.
odoshi
You could try taking your contours off layer 0.
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
doni49
As in something like this?
ElevationRanges-ContoursBlack.dwg
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
in reply to: doni49
Yes this is it.
But it's odd they made it like this.
If contours are in layer 0 or the same layer as surface, contours will be in color of elevation first color. But if contours are in deferen layer they will be in color of layer.
Rail Community
