Laurie is correct. I do not see crossing contours in the image. I see
"contour depressions" that are turned on, and holes in the surface where
a TIN line has been deleted.
Matthew Anderson, PE CFM
Laurie wrote:
> Hi mmf22,
> It looks like you have a style defined to display closed contours for a
> hole with a linetype like _________|___________|__________
> In addition, from the gaps in the contours, it look as though the
> surface model has been edited by deletion of triangle sides.
> Turn on the triangle display to see this.
> Regards,
> Laurie Comerford
> mmf22 wrote:
>> Hi
>> I've created TIN Surface from survey data points. The problem is some of the contours are crossing other contour lines.
>> Would anyone please suggest a way to draw my contour up probly.
>> I've attached a file if anyone wants to have a look and help me.
>> Thanks
