Jason,
I have a survey performed with our GPS that I would like to check the horizontal accuracy on.
I was thinking that a 'least squares' would be the way to go. I have something incorrect because I keep getting a 'degrees of freedom < 1' response when I ask it to run the analysis.
I read your article on BeingCivil.com 'From Grid to Ground...' regarding point file types. I'm thinking that this might be the issue. Can you shed some light on least squares analysis on gps survey data?
Sincerely,
George Mercier
P.S. I've attached our first days .raw data file incase that might help. I've added .txt to the end of course.
I hope you take this as constructive criticism. You are continuing a more than 2 year old thread that quite frankly has nothing to do with the previous problem, other than both are RTK, GPS. This forum has repeatedly requested to start new threads when there are different issues.
Bill
