Switching the Cut/Fill convention in the mass haul diagram,
I’m wondering if there is an option to switch the cut/fill convention in the mass haul diagram such that the fill takes the (+) sign in the cut takes the (-) sign
Thank you
Best
Jamal
Nothing obvious springs to mind (in mass haul analysis cut is always considered to be positive) but what if you swapped the order of the models in the volume calc?
Thanks neilyj,
I can live with the default conventions but wanted to know if that is possible
Best
Jamal
