I find it absurd that AutoCad C3D doesn't have a vehicle sweep routine built in to the design software. This is as basic to roadway design as superelevation is to horizontal curvature. Am I missing something? Is it there, or is there some reason it is not there? Very frustrating.
Buying third party software such as AutoTurn or Pathplanner R4 seems ridiculous.
Solved by sboon. Go to Solution.
I found a much cheaper solution for vehicle turn paths! Rob Gadbaw over at CGS had a great add-on application for vehicle turn paths that was less than $600.00 I would check them out at http://www.cgsplus.com
Works for me on R2012 - R2014. Give them a try...
@mdjones3333 wrote:I found a much cheaper solution for vehicle turn paths! Rob Gadbaw over at CGS had a great add-on application for vehicle turn paths that was less than $600.00 I would check them out at http://www.cgsplus.com
That looks like a great program, but the cost is much higher than $600. The initial license is $1,295 and then a subscription being $395.
I came across this announcement while researching turn path analysis software.
Or the product page directly: http://www.autodesk.com/products/vehicle-tracking/overview
