AutoCAD Civil 3D General
matkain
Message 1 of 8 (229 Views)
Surveyed points v alignment report
229 Views, 7 Replies
09-07-2013 07:16 AM
I have surveyed 100+ points along an alignment. I wish to create a report showing the perpendicular offset, chainage and z value for each point in relation to the alignment, and produce it in a csv or similar spreadsheet format.
How do I do this?
Thanks in advance.
Mat
Joe-Bouza
Message 2 of 8 (220 Views)
Re: Surveyed points v alignment report
09-07-2013 07:46 AM in reply to: matkain
Toolbox tab>> alignment node should have sta off
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
matkain
Message 3 of 8 (215 Views)
09-07-2013 07:57 AM in reply to: Joe-Bouza
Sorry but I don't know what you mean.
New user to civil 3D here. Whats alignment node? whats sta off?
I can see the toolbox tab with the expanded alignment menu. I can't see anywhere that tells me to turn a 'STA' off or on? How does this create a report?
Jeff_M
Message 4 of 8 (210 Views)
09-07-2013 08:14 AM in reply to: matkain
Sta = Station = Chainage
Off = Offset
This report should give you what you want:
Joe-Bouza
Message 5 of 8 (207 Views)
09-07-2013 08:16 AM in reply to: matkain
OOps!
I meant the point node
in the toolbox tab there are nodes / colloection / folders - you know - like an exploreer tree. expand the point folder and there should be station offset report. highlight>> right click>>> execute, then adjust the dialgog for the points and alignment in question.
Tip: I like to export the points of interest make a clean file import the points and alignment then execute the report; its less cluttered, but not essential
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
matkain
Message 6 of 8 (204 Views)
09-07-2013 08:25 AM in reply to: Joe-Bouza
Thanks Joseph
Thanks for the tip. I notice that it includes all points in the drawing.Thats hard when there's 1000 points and you want 300. I'll export the point group I'll need and the alignment I suppose each time I do a report.
Pity you can't pick the points by group or description. (can you?)
Thanks once again and I'll keep stumbling through.
Mat
mikeevans
Message 7 of 8 (183 Views)
09-07-2013 08:38 AM in reply to: matkain
You should be able to select a point group in the reports, "alignment point station offset" report. I've not got c3d in front right now.
If you can't just export and import the data you need to a new dwg.
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
matkain
Message 8 of 8 (177 Views)
09-07-2013 08:58 AM in reply to: mikeevans
Hi Mike
From what I can see you don't have any options for selecting your points. It's all or nothing, or the tedioius task of selecting each point individually with the tick box. I'm a bit lost as to why they give these options for point groups etc. in the drawing but then leave no options to access them.
I'll just go the double handling method of bringing them in to my main drawing, then to another drawing.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
