AutoCAD Civil 3D General
Active Member
Message 1 of 3 (130 Views)
Survey data & shp format (Murph)
130 Views, 2 Replies
09-04-2012 03:41 AM
In a previous thread 'Transfer from total stations ...'
Murph wrote
"Note that with csv format and the suggestions so far works good for land points, name, X,Y,Z and a description. Now if you are doing your electrical towers and need to include other information that you gather while out there then it might be easier to export to Shp format from the Trimble software. Example if you need size, construction type, year build, height, number of lines etc.  Then import or data connect to the shp files."
Sounds as if you import extra information this way, sounds interesting to me ... I'm not familiar with the shp format and the way you link it in map/C3d. Can you shed some light on it? How is your workflow, what is envolved and what are you using the extra information for?
Chr.
*Expert Elite*
Murph
Message 2 of 3 (127 Views)
Re: Survey data & shp format (Murph)
09-04-2012 04:07 AM in reply to: clambrecht
First you need to understand there is a different on surveying/GPSing points for a mapping system and a survey for civil design. Most mapping grade gps units allow you to input extra data in to the units when in the field. Say you are doing a electric power line and gpsing all the poles. You can record the pole size, birth date, number of contuctors on the pole and if the pole also has cable tv or telephone wires on it. Now when you include all that data in the dwg as object data or in the database of the SHP file you can run a query for example to show all pole over 10 years old or what poles also have cable on to make sure the cable co. is following the attachment rules.
Mapimport or data connect (FDO) is how you "link" that data to the dwg.
Murph
Supportting the troops daily.
Valued Mentor
TerryDotson
Message 3 of 3 (98 Views)
09-04-2012 07:23 AM in reply to: clambrecht
If you need to import point based SHP files directly into AECC_POINTS or export points back to a SHP file, that is included in the MapWorks Points module.  Direct read/write, no hoops to jump through.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
