AutoCAD Civil 3D General
rwatson654
Message 1 of 12 (646 Views)
Accepted Solution
Survey - Sewer Structure Invert
646 Views, 11 Replies
03-08-2013 11:25 AM
I would like to find out how other companies handle inverts of sewer structures.  Our field crew dips  sewer structures (measures down to the invert from the top of the structure)  which is probably the norm.  The distance is recorded in our field book.  I created an expression for our sewer point labels that allows the Tech to enter this distance then invert of the structure is displayed.  The expression is simple, top-distance=invert.  This works find unless the survey points have to be inserted again.  The invert is lost and has to be recreated.  Previously it was setup to just type the invert in after calculating.  Please make suggestions on how your firm handles this.  I would like something simple to use that stays with the points.
C3D 2013 (latest updates)
Win 7 Pro, 64-bit
16 GB RAM
*Expert Elite*
TRogers
Message 2 of 12 (640 Views)
Re: Survey - Sewer Structure Invert
03-08-2013 12:13 PM in reply to: rwatson654
Are you wanting the actual "measure down" value?  For example, the 6'?
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
rwatson654
Message 3 of 12 (636 Views)
03-08-2013 12:16 PM in reply to: TRogers
No we would like the invert, which is the top of the structure elevation - measurement down.  The crew shoots the top of the structure and we have a point with a surface elevaiton there.
*Expert Elite*
TRogers
Message 4 of 12 (632 Views)
03-08-2013 12:24 PM in reply to: rwatson654
In the Structure Properties, you can input these values...
All these values can be added to the label style.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
*Expert Elite*
TRogers
Message 5 of 12 (630 Views)
03-08-2013 12:27 PM in reply to: rwatson654
Basically, if you set your sump to 0.00, then your invert will be your sump elevation.  Just bad wording by the Autodesk developers.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
rwatson654
Message 6 of 12 (612 Views)
03-08-2013 01:24 PM in reply to: TRogers
So an imported survey point would be a structure and not a point style with a block.  Have not tried that but will look into it.  What would happen if the points wasre-inserted into the drawing from the survey database.
Valued Mentor
stacy.dunn
Message 7 of 12 (602 Views)
03-08-2013 01:41 PM in reply to: rwatson654
If you are talking about labeling a sewer invert on a survey with a point label, you can use an expression combined with your measure down in a UDP (user defined property) field.  You can create a UDP in your template that can be used to store your field measurements.  This can be imported with your main point data or just the measure down itself.  Once the data is imported, you can use this data in an expression to build your label.
If you re-insert the points, you will also need to re-insert the UDP data.  It is an extra step, but an easy one.  Keep in mind that you will also need corresponding point import file formats for the additional data.
Stacy Dunn
Distinguished Mentor
rl_jackson
Message 8 of 12 (601 Views)
03-08-2013 01:42 PM in reply to: rwatson654
You could also look at utilizing UDP's which would basically do the same thing, put without all the hassel of Pipe Networks. There are tutorials in the help that basically walk you through a similar senario.
****Stacy bet me to the punch****
C3D12-13
Win7x64 6gb
Distinguished Contributor
mikehathaway2942
Message 9 of 12 (535 Views)
03-11-2013 12:47 PM in reply to: rwatson654
We dip hundreds if not thousands of structures a year and merely not the info in the field book and then add a multileader with the pertinent info such as size, depth, flow, flow direction, invert accuracty, etc..... to the symbol.  Haven't had any issues yet.
While I realize there is probably a better way like creating a custom attribute for structures and then having the crew enter that infomation in the code.  I feel there is no need to overcomplicate the simple things.
Active Member
jcaughman
Message 10 of 12 (493 Views)
03-12-2013 06:37 AM in reply to: rwatson654
We 'shoot' the invert in the field.  We'll take a shot on the SMH/DMH, followed by a separate shot on the invert.  This makes the invert shot a point in C3D.  We code the shot so that it has a unique symbol and label ie:  15"RCP(W).  Also, we use linework to join the two inverts of a pipe and add a label to the pipe.  It's all automated in C3D.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
