Our newer collectors have just been upgraded to Survey Pro 5.4.1 and we're having issues converting the .raw files in to .fbk with Survey Link, has anyone else had any issues with this? I have access to Foresight DXM and it will convert the files but for those who don't this could be a pretty big issue.
Solved by rl_jackson. Go to Solution.
Rick Jackson
Survey CAD Technician VI
SP 5.x can create .fbk directly, under Job > Reports.
Be forewarned: it is buggy. I have been unable to create .fbk from some jobs with RTK data. Exporting to .raw and using Foresight has yet to fail, though.
Well... how about that. I just had a flashback to working in DOS. So strange though considering we've converted hundreds/thousands of .raw files with long file names prior to 5.4.1 in Survey Link.
I know Survey Pro can convert directly to a .fbk, most of the time our files are large enough to make it punt though.
Mark
Survey Pro 5.4.1 uses a new*.survey file format which can easily be converted to a number of formats including Autodesks FBK format. There is an external utility program called "Spectra Precision JXL Style Sheet Converter" which can be used to convert your survey data without using Foresight DXM software.
A utility program to apply style sheets to Spectra Precision Survey Pro JXL files.
Zipped Installation Program for the JXL Converter utility.Required for use with Spectra Precision Survey Office v3.30 and Survey Pro v5.5.
Zipped Installation Program for the JXL Converter utility.Required for use with Spectra Precision Survey Office v2.95 and Survey Pro v5.4.
Zipped Installation Program for the JXL Converter utility.Required for use with Spectra Precision Survey Office v2.90.
Spectra Precision Survey Pro Style Sheet Archive.
Survey Pro 5.4.1 uses a new .survey file format which can easily be converted to a number of formats including Autodesks FBK format. There is an external utility program called Spectra Precision JXL Style Sheet Converter, which can be used to convert your survey data without using Foresight DXM software.
http://legacy.spectraprecision.com/survey-pro-downloads.asp?Nav=Collection-71637
