I'm setting up some computers for training some new users on Civil 3D 2011 and Im having problems with importing points and creating figure lines, works great on all the computers in the office, but in the training room can not get the figure lines to assign to the proper layers. They all go on the zero layer. All the setting I see are the same. Any help would be great.
Jim
Solved by jimsoehner. Go to Solution.
Only time I've seen anything like that is when Toolspace -> Survey tab -> Survey User Settings -> Figure Defaults is not configured properly.
Do you have the Figure Prefix Database installed or pathed on that machine?
Whenever I make updates to the Figure Prefix Database I have to make sure IT gets it copied over to each workstation.
Yes finally found the reason, really dumb reason, they all needed to have the two service packs installed.
Just curious: what version is this you are dealing with? We are moving to 2012 soon and it would be nice to iron out all the wrinkles before mass deployment.
I was training on 2011 but I have the survey figures working in 2012 and 2013 I hoping to deploy 2013 in the next couple of weeks. We skip every other version.
