Civil 3D Forum
Survey Figure Linetype
2 REPLIES 2
greenju17
1450 Views, 2 Replies
I shot a Treeline on one of my jobs, and I have it set up to come in as a treeline linetype. But, the problem I am running into is that the linetype scale is not working?  It is supposed to look like a half cloud, but it is showing up as solid line?  I have tried to change the scale, and nothing.  I switched to that layer and drew a line and it showed up like it should, so for some reason it is not showing up correctly as a survey figure??
2 REPLIES 2
SurveyorLee
in reply to: greenju17
I didn't see any other answers here, so here goes..
Look at your model and paper space linetype settings
The command line commands are:
    MSLTSCALE
    PSLTSCALE
The settings are 1 for yes and 0 for no.
If you get the model space to work and the PSLTSCALE (paper space) one does not, there are some other things
that may need to be checked.
Hope this helps.
Lee
DSPatterson
Did you change the linetype scale of the layer, or of the survey figure style?
Edit the survey figure style, go to the display tab, and change the LTS of the layers there, see if that works.
Rail Community
