I'm running into a problem where I can't make a survey figure label style rotate to the object. Here's the label's settings where I've clearly told it to orient by object.
Yet here is what is happening.
You can see that the label for the 30" RCP is not following the direction of the object as well as the UNKNOWN SIZE label on the pipe above it. I can't grip edit or rotate the label in any way. What's going on? Can survey figure labels not be rotated to the object like almost every other label in C3D?
Rick Jackson
Survey CAD Technician VI
@Anonymous wrote:
For what its worth, C3D2013 does not exhibitthis problem.
This is why I get so frustrated anymore with Autodesk. Why would it work in 2013 & earlier, but break in 2014? The amount of quality control is getting pretty pathetic with Autodesk's software.
I observe the same behavior in the 2013 and 2014 versions of Civil 3D. It appears that a figure label orients to the entire figure object, not the selected segment. Since the figure object does not have a rotation property, the label is coming in horizontal.
To get the label to align with the line you may want to use a survey figure line segment label instead of a figure label. In the figure line label style use a reference text component to get the figure name. After placing the label, you will have to edit its properties to assign the figure to the reference text. (It would be nice if the figure name was available as a property in the figure line segment label styles.)
I have no issue, here's a drawing with both line and figure labels - no issue whatsoever with rotation
Rick Jackson
When using the segment labels in 2011-2014, they do work as expected and will align to the object. The issue here is that the Survey Figure labels (New label feature in 2013) do not align with the object they are attached to in 2013 or 2014.
The work around at the moment for the users issue of labeling the figure description, is to use a segment label the has a reference link within the style. As this is not ideal, I will be bringing this issue to our development team.
