Importing a second set of field book points into Civil 3D...however, they do not match up with the first set of points. (ie two points that should be at the same location are different in each of the imports). How can I move a whole set of points after importing without having to select them manually?
Solved by doni49. Go to Solution.
Delete the points that are in the wrong location and then import them to a NEW DB.
Then use the attached to move the whole db to the correct location. Then you can export your points for import into the right DB.
Don Ireland
Engineering Design Technician
