AutoCAD Civil 3D General
Valued Contributor
Message 1 of 4 (281 Views)
Survey Database and Point UDP Labels
281 Views, 3 Replies
11-26-2012 03:57 PM
Hello everybody.....was wondering if someone could enlighten me, cause I think I am making an elementary mistake and can't figure out how to do this.  When I import Points (w/o Survey Database) that contain Point UDP's they come in just fine, (see attached).  However, when I import those same Points thru the Survey Database it does not populate the addition UDP info on the Point Label (see attached).  Why?  I have created the Styles, Point File Format and I have even added data to Survey DB Extended Properties.
Thank in Advance for any replies!
K
Jeff_M
Message 2 of 4 (264 Views)
Re: Survey Database and Point UDP Labels
11-26-2012 09:49 PM in reply to: C3D_User
Hey K, no AU this year?
What version is this in? I thought that this was a wish list item added in one of the recent releases.
Valued Contributor
Message 3 of 4 (201 Views)
11-27-2012 06:09 PM in reply to: Jeff_M
Jeff...thanks for the reply.  I have tried this in 2012 and 2013 to no avail.
Yes I am at AU and will be talking with you later.
K
Message 4 of 4 (190 Views)
11-27-2012 10:03 PM in reply to: C3D_User
There are a few things you need to do. This help page tells you all you need to know.
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/GUID-3E88B795-F2E0-40E8-9F51-E628C3294B93.htm
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
