Civil 3D Forum
Survey Data
4 REPLIES 4
martin888888
350 Views, 4 Replies
Survey Data
I recieved some data today from an outside surveyor who was obviosuly using LDD.  The information I recieved outside of the actual survey autocad mapping was a Autocad .dtm file with the tin linework in it and a zip file with the files shown in the attached document.
Woudl anyone know what the best way to import the surface in the survey master file would be?  Would the ideal way to do this to be to create surface from TIN?
4 REPLIES 4
Maine-iac
in reply to: martin888888
It has been awhile but I believe you are correct with the TIN creation. You should be getting an identical TIN that incorporates all of their edits.
Civil 3D 2022.1
Windows 10 x64
HP ZBook 15 G5
Intel(R) Core(TM) i7-8750H CPU @ 2.60GHz
32 GB RAM
BrianHailey
Yes.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
AllenJessup
If the zip file contains relative paths. Unzip it and allow those paths to be used. If not. Set it up in the standard LDT format; Project Path > Project Name > DTM, Cogo, Align. Then you can import the surface and other dated from Import on the Insert tab.
Usually it is best to leave the surface as the Surveyor supplied it. However, if you need a dynamic surface. If the point and breaklines were supplied in the drawing. You can import the points and breaklines and use them to create a surface.
Allen Jessup
CAD Manager - Designer
rsanchez
There is a Civil 3D command called CREATESURFACEFROMTIN that will import those files directly.  As far as I know, this command only requires the TIN and PNT files, but it's best to keep them all together.  Make sure that you keep them in a common location and that you don't move it.
Ralph Sanchez
Rail Community
