I recieved some data today from an outside surveyor who was obviosuly using LDD. The information I recieved outside of the actual survey autocad mapping was a Autocad .dtm file with the tin linework in it and a zip file with the files shown in the attached document.
Woudl anyone know what the best way to import the surface in the survey master file would be? Would the ideal way to do this to be to create surface from TIN?
It has been awhile but I believe you are correct with the TIN creation. You should be getting an identical TIN that incorporates all of their edits.
If the zip file contains relative paths. Unzip it and allow those paths to be used. If not. Set it up in the standard LDT format; Project Path > Project Name > DTM, Cogo, Align. Then you can import the surface and other dated from Import on the Insert tab.
Usually it is best to leave the surface as the Surveyor supplied it. However, if you need a dynamic surface. If the point and breaklines were supplied in the drawing. You can import the points and breaklines and use them to create a surface.
Allen Jessup
CAD Manager - Designer
There is a Civil 3D command called CREATESURFACEFROMTIN that will import those files directly. As far as I know, this command only requires the TIN and PNT files, but it's best to keep them all together. Make sure that you keep them in a common location and that you don't move it.
