Civil 3D Forum
Surface
1 REPLY 1
dpa-ig
380 Views, 1 Reply
Surface
Hi...
How i can take off or remove the message "finding exterior borders". This appear in the left bottom corner of Civil 3D.....it makes that my computer is very slow...
1 REPLY 1
christopher
in reply to: dpa-ig
It is not somthing you can directly remove. You can check your surface to make sure it is being built with a minimal amount of data and still represent the surface. For instance if the surface is being built from contours, make sure the contours are weeded to reduce the amount of time it takes Civil 3D to analyze all of those vertices. Most of the time in my experience they extra vertices are not needed.
Rail Community
