trynders
Message 1 of 4 (139 Views)
Surface tables...
139 Views, 3 Replies
11-27-2012 07:59 AM
Hi all,
I have a surface that I have done a slope analysis on and want to put a table showing the slope grades.  I have made a viewport and would like to put the table in paperspace.  However, when I zoom in paperspace and regen the table changes size.  How or where do I keep the table from changing size.  It wont let me scale it up or down.
Thanks in advance,
T
tcorey
Message 2 of 4 (127 Views)
Re: Surface tables...
11-27-2012 09:25 AM in reply to: trynders
If you must put the table in paperspace, you can Explode it once. That will create a block that can be scaled. The link back to the surface will be broken. If the surface is modified the table will need to be re-built and exploded again.
If they are to function as designed, Civil 3D tables need to be modelspace objects.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
*Pro
dgordon
Message 3 of 4 (122 Views)
11-27-2012 10:12 AM in reply to: trynders
I'm really surprised it let you put the table up in paper space.    best practice would be to make a new viewport then zoom in on your table that was placed in model space.  Then scale the viewport to the scale you want to view it at.
Once this is done the viewport can be placed anywhere on the sheet you want it and it's fully dynamic.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
trynders
Message 4 of 4 (113 Views)
11-27-2012 11:04 AM in reply to: trynders
I did explode it but it lost the color from the color table.  So I placed it in model space and made a viewport.  It still didn't allow me to scale the viewport and have the table correct size.  I'm thinking it has something to do with the text size of the table.  I will go and re-try it again.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
