Civil 3D Forum
Surface specific C3D hangup...
6 REPLIES 6
Postmaster_G
388 Views, 6 Replies
I was wondering if anyone has had this happen or may have a solution:
I have created two surfaces and a few quick profiles.
When trying to draw a PL and roll over the surface, the OSNAP starts finding endpoints etc and then the drawing hangs up.
I imagine that it is trying to find data or something... but this is getting annoying.
If I turn of OSNAP, the problem goes away.
Does anyone know of a way that I can leave on the OSNAP and not have this happen?
Thank you and happy cadding!
-Meow
6 REPLIES 6
dhenderhan
in reply to: Postmaster_G
I would also like to be able to keep my finger off the F3 button when copying/strecthing/moving/etc within congested areas.  Seems to be something that arose around 2009 release.  Sometimes, my drawings will even crash it gets so bad.  Any help would be appreciated!
David E. Henderhan, PLS
Civil 3D 2023
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
One day Civil 3D developers will fix this problem. I am getting sick of posting about this though! I am sick of using the F3 key. please fix this!
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
lstarbird
+1 for this fix!  Anyone have any luck with a resolution or workaround?  Besides F3?  5 second delays when doing OSNAP on a surface are adding up.  Thanks!
tcorey
Go to OPTIONS command, AEC Editor tab and turn on Object Snap in the Optimize for Speed box. Does this help your performance?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
lstarbird
in reply to: tcorey
Thank tcorey, but it doesn't 😞
dhenderhan
in reply to: lstarbird
No luck here either.
Civil 3D 2023
Intel (R) RTX A2000
128 GB ram
Rail Community
