I was wondering if it's possible to add surface slopes on grid (similar to how there is a tool for adding spot elevations on grid). I can do them individually at a grid spacing but that's tedious, and considering you can add spot elevations on a grid, I'm not sure why this wouldn't be possible.
If there isn't a built-in tool for this, would it be possible to make a block of a bunch of one-point spot slopes and you simply choose which surface & the insertion point when you insert the block?
Thanks!
Use the ARRAY command or COPY the 1 Point slope labels across the surface. If you use ARRAY, make sure that it isn't an an Associative one (they don't like the slope labels).
Cheers,
Peter Funk
