I use Civil 3D 2011 and I am new to it.
I have created a natural ground surface from survey points. Now i want to create a finished surface with a specific slope in a specific direction at a specific elevation and then to calculate cut and fill volume.
I can create a flat surface at a specific elevation. Please let me know how to tilt this surface to a specific slope along a specific direction.
Thanks in advance.
Please explain me in little detail with steps.
My design surface is like the red polygon shown in the picture attached and the direction of slope is marked by the green arrow. Thanks.
Joe Bouza
Joe-Bouza wrote:
As the saying goes... there are many ways to skin a cat...
ignoring what the outline is, one can assume a uniform grade accross the whole object. In this case you could:
1. draw a FL from corner to corner as your green arrow shows (Point A-B, at the designed slope.
2. offset the FL beyound the figure on either side at zero slope
3. make a temp surface of the 3 FL
4. make a FL of yhe red outline ( in a different site) then extract the elevations fron the temp surf to youe verts
I tried, it works fine. Thanks! 🙂
Now, when I create the surface, i notice that the border (yellow colour) of the surface is bigger than the surface area (red colour) which i used to create the surface.
I use a much bigger natural surface as the base surface and use this new surface as the comparison surface to calculate my cut and fill volume. In the panarama, i get the cut volume and fill volume.
Now my question is:
1. The cut volume and fill volume i see in the panarama are the cut and fill volume of the area bounded by yellow or it is the cut and fill volume of the area bounded by original red polygon?
Actually my requirement is to get the cut and fill volume of the area bounded by my original red polygon.
2. How to get a report of this volume analysis in an external file?
Thanks.
For display purposes, you can add the red line as a 'outer' boundary to your surface (look in the surface definition tree).
Similarly, to be sure you are getting exactly what you want - get the bounded volume (right click the volume surface to see this option), i.e. the volume bounded by the outline you select.
To output the analysis - go to your volumes dashboard, add your volume surface, then select the 'generate cut/fill report' icon at the top of the window.
Regards
- Mick
Mark Green
Working on Civil 3D in Canada
I tried both the methods mentioned by Mike and Troma, both works fine. Thanks a lot!
I use Civil 3D 2011 and there is no volume dashboard in it. It has Composite Volumes in Panorama where I see the cut and fill volume. There is no button for "Export volume entries to file". So, I think generating a report to an external file is not possible in Civil 3D 2011.
Thanks.
There is no need to make a new pline for the border. If the red feature line is closed just use that feature line as the border also.
John Mayo
Here: (screenshot taken in 2011).
BTW, with the border, I was assuming it was originally drawn as a pline, not a fline. So I was trying to save a step in conversion.
Mark Green
An dynamic average end area calc can be performed within the dwg using materials and a takeoff. A dynamic table can also be saved in a dwg.
Search Civil 3D compute materials in Help, YouTube or Google for more.
Also note that you may want to consider doing the volume calc in a different dwg with data references to your EG and FG surfaces if you will be plotting cross sections.
John Mayo
