Civil 3D Forum
Surface problems
2 REPLIES 2
340 Views, 2 Replies
Surface problems
In the surface image attached the magenta line is a contour (492.8'). Any ideas why I'm getting triangulation down the middle? There shouldn't be anything for the surface to be tying to. Thanks,
2 REPLIES 2
jmayo-EE
Did you use the Minimize Flat Areas edit on the surface?
If so edit your style and disply the surface points. THis will show you the data that the command above added to your surface to prevent the contour from failing (crossing back and forth) in the flat area.
John Mayo
in reply to: jmayo-EE
Forgot about the edits. Removed them and it fixed my surface. Thanks,
Charles Neely | Senior Water Resources Technician
O'BrienEngineering, Inc.
Engineering & Environment
p: 972.233.2288
[http://www.obrieneng.com/sdvosb2.jpg]
Service Disabled Veteran Owned Small Business
Since 1987 | TBPE Firm License No. F-3758
This electronic email and all information and data herein, including any file or drawing attachments is confidential and privileged and is intended for the sole use of the individual(s) to whom it is addressed. If you are the intended recipient, further disclosure is strictly prohibited without previous and proper authorization. If you are not the intended recipient, please notify O'Brien Engineering, Inc. immediately at 972-233-2288.
Rail Community
