AutoCAD Civil 3D General
Valued Contributor
diegoal
Message 1 of 5 (170 Views)
Surface memory size
170 Views, 4 Replies
12-11-2012 06:21 AM
Hello guys,
How can I know the memory size of a TIN or DEM surface? I have a very dense points data to create a surface and I would like to test what option would be the best: simplify the surface removing points or make it raster...
Thanks!
Diego Álvares
Civil Engineer - www.trentoengenharia.com.br
Autocad Civil 3D 2013 / 2014 / 2015 - Infrastructure Design Suite
Windows 7 64 i7 4770 @3.40GHz 8GB Ram GeForce GT 630
TRogers
Message 2 of 5 (165 Views)
Re: Surface memory size
12-11-2012 06:46 AM in reply to: diegoal
One option would be to create the surface in a new, clean drawing.  Then data shortcut in the surface to your project files.  This will keep your drawing file sizes to a minimum and your memory usage down.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
troma
Message 3 of 5 (163 Views)
12-11-2012 06:54 AM in reply to: TRogers
You could also copy the drawing with nothing but the surface in it and test the different methods of reducing the file size.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Contributor
seattlesurvey
Message 4 of 5 (140 Views)
12-11-2012 11:38 AM in reply to: diegoal
Also, remember that the drawing size will be impacted by the surface style in use when last saved.  For example, your saved drawing will be smaller if the surface style is a "No Display" style versus a style which displays contours and TIN lines.
HTH.
Valued Contributor
diegoal
Message 5 of 5 (135 Views)
12-11-2012 11:50 AM in reply to: seattlesurvey
Thanks guys, what you are suggesting can indicate the proportional impact of each surface... and maybe it should be good enough.
But I was expecting to calculate the TIN memory size by the number of triangles and its size in bytes vs the number of pixels and its size in bytes. So I guess I should write a VB code to be able to get the number of triangles (TIN) and valid pixels (DEM).
Isn't this the memory size of these ARX objects?
Diego Álvares
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
