I have a surface of a treatment Pond setup and everything is fine with the Original. But it is in a high water table area so the first one was designed to be all Fill. When I do a Balanced Pond by lowering the contours is where I am having problems.
I manually drew Contours showing the inside of the Pond and the lip just over the edge. This will not change and I know what it should look like. I then Graded to Daylight and turned on the contours to show what it should look like. Like I said above the all Fill one I did at first is fine, but when I lowered my Contours to make a balanced design my contour lines start looking like zigzag or insulation line types in a couple areas. And it only happens the the portion I used grading on? See Pic...
Andy Warren
BCDesign@bellsouth.net
