Civil 3D Forum
Surface from corridor problem
8 REPLIES 8
Message 1 of 9
367 Views, 8 Replies
Hi everybody,
As i mention I have a problem with a surface generated from a corridor - I cannot set the boundaries
I add as boundary the corridor and it's not working
I also add the daylight as boundary and it's still not working
Does anybody know how to solve it or it's a bug
8 REPLIES 8
Message 2 of 9
i forgot to mention that the cross section looks like in the second attachment
Message 3 of 9
ToddRogers-WPM
Select "Use corridor extents as boundary".  What version are you using?  You might have to rebuild the surface, or rebuild the corridor.
Todd Rogers
Message 4 of 9
in reply to: ToddRogers-WPM
thank for your reply
I already try that and it's not working
iI'm using civil 3d 2013 with no updates
Message 5 of 9
Joe-Bouza
When you go to select the boundary type is the option for P2 there? try that
Joe Bouza
Message 6 of 9
in reply to: Joe-Bouza
No P2 option. What is this P2 option ?
I install the SP2 and the surface looks better but not as it should be
Message 7 of 9
sboon
Post the drawing as an attachment so that someone else can take a look at it.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 8 of 9
ksorsby
I find that adding a boundary interactively often works when the corridor shrinkwrap doesn't. You can effectively chop out troublesome areas.
Kevin
Message 9 of 9
in reply to: ksorsby
I installed all SP and I did the surface again and now it seems to work
thanks everybody for your help
Rail Community
