Ok we have 6 identical PC's all with the same drivers, same support paths, same plotter paths. Only one PC will not print surface contours. I can open the same file(s) on any other PC and the things print w/o issue. This one PC will not print the srf contours on only a few files. Most files there is no issue...
Any insight to this issue? Quite odd that it's only one machine messing up with a few files that another machine has no issue with.
John Mayo
Solved by Jay_B. Go to Solution.
Pretty sure it's a drawing and not a user setting but is "Level of Detail" off from the machine that won't plot the contours?
Excellent work there Jay. I have never purposely used that function and must have clicked it by accident unless C3D is turning it on automatically.
John Mayo
Mark Green
Working on Civil 3D in Canada
Level of detail is not a drawing setting, to my knowledge. I ran into this same exact problem before. One user like using LOD and the other didn't.
