AutoCAD Civil 3D General
Active Member
randallconner
Message 1 of 3 (162 Views)
Surface disappears when viewed wit LT or Trueview
162 Views, 2 Replies
08-03-2013 10:16 AM
I created a DWG with Civil 3D.  When it is viewed with LT or TrueView the contours for the surface disappears.  I checked the detail switch on the VIEW tab but it did not seem to make any difference.
Is this a function of LT and TrueView?
Alfred.NESWADBA
Message 2 of 3 (157 Views)
Re: Surface disappears when viewed wit LT or Trueview
08-03-2013 10:23 AM in reply to: randallconner
you should install the object enabler for Civil3D from >>>here<<<
HTH, - alfred -
Alfred NESWADBA
sboon
Message 3 of 3 (121 Views)
08-03-2013 09:01 PM in reply to: Alfred.NESWADBA
Another option might be to make sure that the PROXYGRAPHICS variable is set to 1 before saving from Civil3D.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
