Hey all,
This is driving me crazy! Hope you can help. I am running Windows 7 Professional 64-bit. Civil 3D 2013.
I have two surfaces (existing and proposed). I have two alignments (2 roadway centerlines). Profile view for alignment #1 is fine, both surfaces have full data and looks great. Profile view for alignment #2 has full data for the existing surface, but is missing data for the proposed surface (see attached.)
I have audited, recovered, deleted alignment #2 and recreated, deleted data shortcuts and reassigned. Feel like I've tried it all.
Why isn't the data being read for alignment #2, but it is for alignment #1??
It looks like the station and elevation columns are blank in your screenshot. No station range.
Not sure how that happened. Did you mention it was a data shortcut?
Mike
Are the surfaces sync'd and displaying correctly in the drawing? Maybe try saving and re-opening the drawing to make sure the surfaces can come in, then try the profile command again.
Have you tried removing the FG Surface shortcut and bringing it in again? You'd have to add it back to both profile views.
@Anonymous wrote:
Exactly. That is what I'm having trouble with. The alignment is in the drawing, the surfaces are data shortcuts.
Is it possible that the FG Surface in question is data referenced and also has the FG Surface source dwg Attached to this same drawing as an Xref?
