Civil 3D Forum
Surface creation problem
2 REPLIES 2
256 Views, 2 Replies
I'm using Civil 2012 to create a surface for a landfill. I have UTM coordinates, and my elevations range from about 71m to 115m. When I create my surface using the points, I check the Surface Properties/Statistics, it appears the X,Y & Z coordinates have been scaled down by 3 decimal places. I'm using UTM coordinates to create the points.
Example:
Min elevation = 0.071m .... should be 71m
Min X = 481.510m etc. ... should be 481510.99 or something similar.
Units are set to meters.
Any help greatly appreciated!
-Jason M.
2 REPLIES 2
Jay_B
Are the Coordinate Units on Ambient Settings tab of Drawing settings dialog set to meters or mm?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: Jay_B
Thanks for the quick reply. Upon checking the drawing settings, the units were set to MM. Once I changed that, my surface seemed fine, and I was able to generate contours. Everything looks fine now, thanks so much! -jason m.
Rail Community
