Hello. I have three surfaces; A, B, and C. Surface A is pasted into Surface B. Surface B is pasted into Surface C. I update surface A, so I want to delete A from B. After this happens everything else that is in Surface B is deleted as well (other surfaces). The drawing says unable to write file when trying to save and shuts down with an error. Something is wrong with the drawing, more specifically I think the Surface A because I have 8 other surfaces pasted into B, all of which I am able to delete with no problems. This will probably need attention from the autodesk crew. I would go through support but am unable to get the home page for autodesk to load and I only have discussion groups saved to favorites. If an autodesk person wants the drawing I can send it through a FTP site. Thanks for the help.
Brandon
