New Member
nayanakantha843
Message 1 of 3 (277 Views)
Surface and volume calculation
277 Views, 2 Replies
11-13-2013 06:55 PM
I attach picture 1 and 2. please see it
i need crate surface like this pictuire 2.
i need crate surface by joining 1, 2, 3 like as picture 2 section
but when i crating surface its joining as picture.
this problem have been found
i crated a tofo of the rock which rock is bend lower picture 2 section
to calculate the volume i need the surfce crate like this.
please anyone can replay for slove this dout or another method for calculate volume
JSpell
Message 2 of 3 (258 Views)
Re: Surface and volume calculation
11-13-2013 08:23 PM in reply to: nayanakantha843
You won't be able to have a single surface with multiple z values.  Triangulation shape is horizontal only, so this doesn't allow for a single over lapping surface.  I would stick with multiple surfaces and try to make that work.
neilyj
Message 3 of 3 (236 Views)
11-14-2013 12:03 AM in reply to: JSpell
You may find some guidance here http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-B75FEF9F-1020-4E66-B1B4-196732B... but you will need to split the surface you have into two; upper and lower
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
