I attach picture 1 and 2. please see it
i need crate surface like this pictuire 2.
i need crate surface by joining 1, 2, 3 like as picture 2 section
but when i crating surface its joining as picture.
this problem have been found
i crated a tofo of the rock which rock is bend lower picture 2 section
to calculate the volume i need the surfce crate like this.
please anyone can replay for slove this dout or another method for calculate volume
Solved by neilyj666. Go to Solution.
Solved by JSpell. Go to Solution.
You won't be able to have a single surface with multiple z values. Triangulation shape is horizontal only, so this doesn't allow for a single over lapping surface. I would stick with multiple surfaces and try to make that work.
neilyj (No connection with Autodesk other than using the products in the real world)
