Civil 3D Forum
Surface analysis range colours
5 REPLIES 5
neilyj666
1455 Views, 5 Replies
Is there a way to automatically adjust the cut range colours (REDS) in the attached scheme such that the lighter colours denote lower cut depths in the same way that the fill range does (Greens)
I know they can be manually adjusted but when the analysis is run again the colours revert back
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
5 REPLIES 5
ralstogj
in reply to: neilyj666
You use to be able to do it by editing the .arm file found at the location in this post then they broke it not sure if its fixed in 2013
http://c3dxtreme.blogspot.com/2011/05/editing-civil3ds-default-color-banding.html
Regards
Justin Ralston
neilyj666
Thanks for this - I just tried swapping the order of the reds but makes no difference to the colour scheme.
autoMick
I think this is what you are after: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Custom-color-range-for-surface-elevations/m-p/3396357...
it works a treat. Cheers
- Mick
Civil3d user in Australia since 2012.
neilyj666
in reply to: autoMick
Thanks for this - I did the export/import analysis method although this functionality really should exist OOTB
dasindog
I agree, but I'm glad you brought this up. What a time saver!
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
Rail Community
