Is there a way to automatically adjust the cut range colours (REDS) in the attached scheme such that the lighter colours denote lower cut depths in the same way that the fill range does (Greens)
I know they can be manually adjusted but when the analysis is run again the colours revert back
Solved by autoMick. Go to Solution.
You use to be able to do it by editing the .arm file found at the location in this post then they broke it not sure if its fixed in 2013
http://c3dxtreme.blogspot.com/2011/05/editing-civil3ds-default-color-banding.html
Thanks for this - I just tried swapping the order of the reds but makes no difference to the colour scheme.
I think this is what you are after: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Custom-color-range-for-surface-elevations/m-p/3396357...
it works a treat. Cheers
- Mick
Thanks for this - I did the export/import analysis method although this functionality really should exist OOTB
