AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 7 (312 Views)
Surface Table Names
312 Views, 6 Replies
07-06-2011 04:29 AM
Is there a way for a table linked to a surface (ie. a volume table) to display the surface name in the header? There seem to be no options to do so and copy/pasting <[surface name]> into the header text box just returns a number, oddly.
I will have upwards of 40 surfaces and I don't want to have to manually edit each one!
Seems like a bizarre and simple omission seeing as the tables are dynamically linked to the surface anyway.
Any ideas?
Cheers,
Kevin
*Expert Elite*
Message 2 of 7 (299 Views)
Re: Surface Table Names
07-06-2011 09:02 AM in reply to: ksorsby
I ran into that issue once.  Unfortunately, I found no good way to do it.
For me, it wasn't too bad, because I only had a couple of Surfaces, so I created a Table Style for each one.  I wouldn't want to do that for 40 Surfaces, though...
Sinc
Message 3 of 7 (288 Views)
07-06-2011 10:03 AM in reply to: Sinc
I thought as much. I'm going to file this one under Half-Baked Functions That Autodesk Can't Be Bothered To Sort Out.
Cheers,
Kevin
*Expert Elite*
Message 4 of 7 (282 Views)
07-06-2011 10:27 AM in reply to: ksorsby
Yeah, there's an awful lot of C3D that falls into the "half-baked" category....
It gets frustrating.  But on the flip side, it's possible to do an incredible amount of high-quality work in a very short time frame with this software, even in its current "half-baked" state.  So if it ever gets "fully baked", it should be pretty awesome...  :smileywink:
Sinc
Message 5 of 7 (171 Views)
12-19-2012 09:16 PM in reply to: Sinc
Plus one... Please ADD!!
Civil 3D 2014 (SP1)
Win 7 Pro x64
DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680)
24Gb Ram
NVIDIA Quadro 2000 (1GB)
Valued Contributor
Message 6 of 7 (144 Views)
01-03-2013 03:58 AM in reply to: bkanthergolder
can you insert a field into the table style? use object. then name... just guessing at this point
Windows 7 64
Intel Core i7 2.0 GHz 2.0 GHz
8 GB RAM
Nvidia GeForce GTX460M
Civil 3D 2012 SP2.1
Message 7 of 7 (128 Views)
01-04-2013 02:23 AM in reply to: d1of2
There's no option or dropdown that I can see to enter anything other than text into the header text component editor.
It's a royal PITA when you've got a lot of tables lying around.
Kevin
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
