I asked a question earlier about how to change the contours of cut/fill to red/green and I figured out how to change everything individually (one grading at a time).
But is there a way to change the 2' and 10' contours (design) surface style so that it always makes cut red and fill green? Like in this video: https://www.youtube.com/watch?v=7nTiZnYDKdw
I dont want to have to go to every grading and manually change the colors everytime.
I'm not sure about contours, but you can create a volume surface and display the elevation banding shaded behind your contours. With the volume surface it is easy to depict cut and fill using the banding since you have positive elevations being either cut or fill and the negative elevation being the opposite - depending on the base and comparisson surface definition.
It is possible to set up two contour ranges in a surface style, with different colors, linetypes etc for each. In this case I've set up a style with two ranges and set the colors to red and green.
Use the Analysis tab of the Surface Properties to apply the two ranges. If you want the split between them to be at a specific elevation then you can set that also.
