Civil 3D Forum
Surface Slope Labels - Rise:Run Custom Labels
2 REPLIES 2
jbalaneski
1532 Views, 2 Replies
I am trying to create a surface rise:run slope label for our company template file.  I have it set using the default values that I want.  But right now the text is just 1:1...where we want it to read 1V:1H.  Does anyone know how I can keep the label dynamic to the surface, but put the V & H in the label after the values.?
2 REPLIES 2
Jeff_M
in reply to: jbalaneski
Create an Expression for the slope labels, name it Run. The actual expression is 1/{SurfaceSlope} format as double. Then use this for your style. Here's what the Text Component editor will look like:
jbalaneski
in reply to: Jeff_M
Thank you so much Jeff! That worked perfectly!  I'm sure you hear this all the time...but you are a GENIUS!!!  Thanks again! You saved me from pulling out the last few hairs on my head.
Rail Community
