Civil 3D Forum
Surface Profiles
4 REPLIES 4
145 Views, 4 Replies
Surface Profiles
I've been playing around in Civil3D with some previous jobs we've done in LDT. I noticed that if you create an alignment that coincides with points in the surface, that sometimes, the surface profile will just stop at one of those points and not calculate anything beyond it. I've had it happen three times to two different alignments in the file. If I slightly modify the surface, it then calculates the rest of the surface profile. Anyone else seen this rather odd behavior? Brian
4 REPLIES 4
Brian, I am not seeing this behavior with the Sp1 build. I tried to both create and edit an alignment that snapped to points in the surface. If you are able to reproduce the problem again, please attach (or email the drawing). thanks, Daniel Philbrick ISD Civil Development. "Brian Hailey" wrote in message news:4033a83c$1_1@newsprd01... > I've been playing around in Civil3D with some previous jobs we've done in > LDT. I noticed that if you create an alignment that coincides with points > in the surface, that sometimes, the surface profile will just stop at one of > those points and not calculate anything beyond it. I've had it happen three > times to two different alignments in the file. If I slightly modify the > surface, it then calculates the rest of the surface profile. Anyone else > seen this rather odd behavior? > > Brian > >
Hi Daniel, I'll try to recreate it and post back. Brian "Daniel Philbrick" wrote in message news:4036084d$1_3@newsprd01... > Brian, > > I am not seeing this behavior with the Sp1 build. I tried to both create > and edit an alignment that snapped to points in the surface. If you are > able to reproduce the problem again, please attach (or email the drawing). > > thanks, > > Daniel Philbrick > ISD Civil Development.
I'll post the drawing in customer-files with the topic "Surface Profiles (Civil3D)". Brian "Brian Hailey" wrote in message news:40363182_2@newsprd01... > Hi Daniel, > > I'll try to recreate it and post back. > > Brian > > "Daniel Philbrick" wrote in message > news:4036084d$1_3@newsprd01... > > Brian, > > > > I am not seeing this behavior with the Sp1 build. I tried to both create > > and edit an alignment that snapped to points in the surface. If you are > > able to reproduce the problem again, please attach (or email the drawing). > > > > thanks, > > > > Daniel Philbrick > > ISD Civil Development. > >
Brian, Thanks for the drawing which clearly illustrates the problem. Dan Philbrick "Brian Hailey" wrote in message news:4036801e$1_3@newsprd01... > I'll post the drawing in customer-files with the topic "Surface Profiles > (Civil3D)". > > Brian > > "Brian Hailey" wrote in message > news:40363182_2@newsprd01... > > Hi Daniel, > > > > I'll try to recreate it and post back. > > > > Brian > > > > "Daniel Philbrick" wrote in message > > news:4036084d$1_3@newsprd01... > > > Brian, > > > > > > I am not seeing this behavior with the Sp1 build. I tried to both > create > > > and edit an alignment that snapped to points in the surface. If you are > > > able to reproduce the problem again, please attach (or email the > drawing). > > > > > > thanks, > > > > > > Daniel Philbrick > > > ISD Civil Development. > > > > > > >
Rail Community
