AutoCAD Civil 3D General
troma
Message 21 of 63 (234 Views)
Re: Surface Manipulation
02-14-2013 06:38 AM in reply to: Joe-Bouza
Joe-Bouza wrote:
My diagram shows that anything in the proposed section below FG increase the total cut.
Does it increase the cut, or reduce the fill?  You'll never know if you don't go... and model it!
EG -vs-FG surface analysis:
Cut:                                                        100 cubic meters
Fill:                                                         200 cubic meters
Unadjusted net                                100 cubic meters (F)
Area depth Adjustments for pavement, topsoil, structures etc.: 300 cubic meters
Is that 300 I'm taking out of the fill number in the tender, or adding to the cut number?  Or a bit of both?
Total adjusted earthwork:           200 cubic meters (C)
I enjoy the debate
Me too. :smileywink:
but no one has mathematically proved this wrong yet :smileywink: show me the numbers :smileywink:
I'm using logic, not specific numbers, but I think my point is clear enough.  Look at the diagram you drew.  If you calculated your "Unadjusted net" and then added the adjustment, how would you know the total cut number and total fill number?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Joe-Bouza
Message 22 of 63 (229 Views)
02-14-2013 07:08 AM in reply to: troma
I know its logic that what my diagram is based on.
I think we can all agree that we have to cut to the datum but we do not have to fill to FG where a proposed element is, and that it what my diagram shows. I don't see the need to model it. If subtract the green area from the fill or add to the cut I still reduce the fill.
not exactly sure what you mean by tenders
Cut:                                                        100 cubic meters + 200 cubic meter = 300 cubic meters
adjusted net                                100 cubic meters (c)
If you did a cut and fill from EG -vs- Datum you get my diagram.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Mentor
fcernst
Message 23 of 63 (225 Views)
02-14-2013 07:12 AM in reply to: Joe-Bouza
  1. 'If total earth work is done between FG an EG"
Not true. Earthwork should be done as compared between the proposed design subgrade elevation (FG-Subgrade) and a topsoil stripped (per soil report boring logs) existing ground surface (EG-Stripped).
2.  "sidewalks curbs drainage structures will always increas the total cut on a job.'
Not true. If the proposed design subgrade elevation for these structures is above the EG-Stripped surface, this area would be in Fill. Since the area is now established to be in Fill relative to FG-Subgrade compared to EG-Stripped, there is no increase in Cut in these areas.
Cut occurs when Elev(FG-Subgrade)-Elev(EG-Stripped) < 0
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
troma
Message 24 of 63 (218 Views)
02-14-2013 07:33 AM in reply to: Joe-Bouza
You're still missing my point.  Point is: I need to know the Cut and the Fill, not just the Total of them both together.
The form of tender is the document supplied by the consultant to the contractor with a list of items in the contract.  Part of that will inculde the amount of cut-to-fill on site, and the amount of imported fill required.  Your method would acurately calculate the amount of fill to be imported or exported, but not the cut-to-fill item.
Using these numbers, the unknown quantity is the '+ 200 cubic meter'.  This has been calculated by area x depth, and we don't know if the area is in a cut or fill situation.  Therefore, if it is all in cut, the item for cut-to-fill would be 200 cubic meters (since that's all the fill we need).  But if it is all in a fill area, we could now have zero fill, and the same item in the tender would be zero.  Most likely the reality would be somewhere in the middle, but like I said, you won't know if you don't go.
I think Fred understands me.:smileyhappy:
Joe-Bouza
Message 25 of 63 (212 Views)
02-14-2013 07:36 AM in reply to: troma
It is computing the totals. thats all
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Valued Mentor
fcernst
Message 26 of 63 (202 Views)
02-14-2013 08:40 AM in reply to: fcernst
I should note that, at a minimum, organic topsoil material should be stripped from the EG surface for earthwork per soil boring logs.
I am thinking of a site we recently had where it was clearly stated in the geotech's site soil report that a layer of inorganic fat clay soil, as depicted in the soil boring logs, was suceptible to frost heave, and was not suitable to be used as Fill.
It is imperative to have an understanding of the site soil report.
Fred Ernst, PE
C3D 2015
Ernst Engineering
neilyj
Message 27 of 63 (197 Views)
02-14-2013 08:50 AM in reply to: fcernst
What sort of material is this - never heard anything described like this before?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Neilw
Message 28 of 63 (193 Views)
02-14-2013 09:05 AM in reply to: Joe-Bouza
Joe,
Perhaps I misunderstood your original comment or you misunderstood mine. To clarify my comment I'll present a scenario.
Consider a 5 acre paved parking lot. The pavement structure is 1 foot thick. It was modeled with gradings so there is no subgrade surface available. The FG varies in cut/fill condition throughout the site. How do we compute the earthwork volume (ignore stripping and other factors for simplicity)? We can't just multiply 5 acres times 1 foot deep and add it to the computed FG-EG surface volume. Nor can we mulitple 5 acres x 1 feet deep and subtract it from the surface volume. We would need to apply different formulas for cut vs. fill to compute the earthwork volume to the subgrade.
From your diagram I gather you are taking this in to account, but how do we determine the areas that are in cut or fill? As I mentioned, we could generate ISOPACH contours and use those to determine the cut/fill areas, but it is a labor intensive process when you have to break the areas into pieces according to variations in the depth to subgrade.
So I'll wait for your clarification on your solution.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Valued Mentor
fcernst
Message 29 of 63 (189 Views)
02-14-2013 09:23 AM in reply to: neilyj
Liquid Limit >= 50 and High Plasticity
Fred Ernst, PE
C3D 2015
Ernst Engineering
Joe-Bouza
Message 30 of 63 (185 Views)
02-14-2013 09:37 AM in reply to: Neilw
Hi Neil
If I may answer with another question or two with the same criterior as you outlined
1. if the 5 acre parking lot is design 100% in fill  then multiplying 5 acre by 1 foot and subtracting  from the gross fill would give the corrected fill volume, no?
2. like wise If the 5acre parking lot is designed 100% in cut, adding 5 acre-feet to the cut would be the correct volume.
There by superposition the same hold true for sites in cut and fill, no? You do not need to know which areas are in cut or fill as the diagram shows anything in fill is actually a reduction in fill needed or negative F and negative F = C.
It took me a while to swallow too. Its algebra plain and simple.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
