Civil 3D Forum
Surface Labeling: Display Contour Label Line...default to False?
10 REPLIES 10
Message 1 of 11
SteveAdams8888
11156 Views, 10 Replies
When I label contours by "Contour Multiple", I get a line going thru my contours. I can remove this thru the Properties pallette.
Is there a setting somewhere to make it default to not draw a line?
Steve
C3d 2010 (no SP)
Win7
10 REPLIES 10
Message 2 of 11
marcross
in reply to: SteveAdams8888
Toolspace>Setting, right click on Surface>Edit feature Settings>Contour Labeling Defaults>Display Contour Label line = False
Message 3 of 11
SethHall
Hi Steve-
You can change existing labels by selecting the labels and going to the CONTOUR LABEL LINE PROPERTIES and setting the DISPLAY CONTOUR LABEL LINE to FALSE:
You can also set this in the command setting by editing the AddContourLabeling DISLAY CONTOUR LABEL LINE to FALSE. This way you will never see the line when labeling:command.png
Seth Hall
Product Owner
Model Builder
Message 4 of 11
SteveAdams8888
in reply to: SethHall
Thanks marcross and Seth. I appreciate that!
Steve
C3d 2010 (no SP)
Win7
Message 5 of 11
CrazyIvan
I do not see this option in Civil3D 2010.  Is it located elsewhere in 2010?
Message 6 of 11
Jay_B
in reply to: CrazyIvan
Should be here.
Settings Tab of Toolspace>Rt. click on "Surface">Edit feature Settings>Contour Labeling Defaults>Display Contour Label Line = False
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 11
CrazyIvan
in reply to: Jay_B
Not on mine. See attachment.
Message 8 of 11
Jeff_M
CrazyIvan, rt click on Edit Feature Settings, NOT on Edit Label Style Defaults.
Jeff_M, also a frequent Swamper
Message 9 of 11
CrazyIvan
in reply to: Jeff_M
heh.  my imaginary dislexia strikes again. LOL  Thanks.
Message 10 of 11
twillis004
Weird, I followed this string but when I set the Contour Label Line False , its still showing up?  What is up with that?
Message 11 of 11
Jay_B
in reply to: twillis004
The Command Settings here will only affect newly added label lines.
Select the existing labels>Properties Palette>Display Contour Label Line>False.
C3D 2018.1
C3D 2016 SP4
Rail Community
