Because a surface is defined by points and faces/edges. Anything else is
just fluff. LandXML is designed to be the ASCII of the development
world, and just as you don't get the table definitions or page numbers
etc when you save a word doc into .txt, you won't get all the stuff
behind a surface, you just get the surface.
LandXML is primarily for trading between apps. While it has uses moving
C3D to C3D, it's not designed for that, so it won't reflect the full C3D
buildup of a surface.
HTH
James Wedding, P.E.
Engineered Efficiency, Inc.
The Site: www.eng-eff.com
The Blog: www.civil3d.com
The Book: www.masteringcivil3d.com
C3D 08SP2/09 Mac Book Pro, XP SP2, 4GB
