I have a drawing that someone else created that has a spot elevation label for a surface. It labels the surface (PAD) then automatically subtracts a set distance for another elevation (GFE) and adds a set distance for another elevation (FFE). After doing some research, it looks like it was created with an expression?
I have two questions:
First, can someone direct me on where to go to get a better understadning of this? I'm not familiar with expressions.
Second, where can I find the expression in drawing to make an edit to the set distances. I can remove the GFE/FFE as they are separate components in the label style, but I don't see where to modify the distance it adds or subtracts.
Any help would be greatly appreciated. Also, I'm still in '09, in case that makes a difference.
-Tucker McKenzie
Not sure how useful this is as I'm not familiar with 2009 but for later versions you need to go to Toolspace > Settings > Surface > Label Styles > Spot Level > Expressions.
Right Click on Expressions, Create New, give it a name and hit the top row button second from right and this wil allow you to select various components (e.g. Top Concrete - itself an expression) and deduct 2.75 from it. You should see the PAD GFE and FFE listed
and these can be edited by right clicking
neilyj (No connection with Autodesk other than using the products in the real world)
