Civil 3D Forum
Surface Drawing triangles accross my breakline
5 REPLIES 5
willpyle7693
1213 Views, 5 Replies
I have a survey figure my drawing that i am trying to add as a breakline. i have not been able to get this particular line to work as a breakline and the surface keeps drawing triangles through the line like its not even there. The figure properties show that it is a breakline. The figure prefix database brings the line style in as a breakline from the start. what could be the problem?
5 REPLIES 5
sboon
in reply to: willpyle7693
Your surface build options include controls for how to deal with crossing breaklines.  It's possible that with your current settings the breakline is being ignored by the surface.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
willpyle7693
Yes. I see now that the line is supposedly crossing another line but I don't see it.
willpyle7693
in reply to: sboon
when i try to add these lines that are being ignored, the event viewer tells me that the breakline crossed a breakline at multiple locations. I have tried removing the figure from the drawing and reinserting, i have visually inspected the line and can see that it does not cross any other breaklines. What gives?
troma
Have you tried running the breakline tool to find and resolve the crossing breakline?
Mark Green
Working on Civil 3D in Canada
_Hathaway
I too have experienced this phenomenom and it is definitely frustrating. Try to resolve the crossing breakline like Troma says. This could be a dwg crasher too as I find that tool be extremely taxing on your system if you have a lot of breaklines,
I prefer the old LDD layering of srf-flt that contained all breaklines, nothing was hidden and you could see all breaklines very easily. Sometimes in Civil3d the breaklines get nested (they exist but there is no linework associated with it) This is what I suspect has happened here. If so, you will have to go to your surface and individually select each breakline and zoom to it, find the suspect breakline and delete it. There may be better methods but that's what I have done in the past.
Rail Community
