I created some about 20 cross sections for a creek we topo'd and then went to work making the topo itself look presentable. After I was all done with that I noticed my cross sections had lost the surface data and were now just an empty grid.
When I go to edit a cross section's properties in the elevation tab the "Automatic" choice has a minimum and maximum elevation of 0. When I use one of those existing sample lines to create a single cross section the same thing happens, it's not picking up data from the surface. However, when I made a new sample line along the existing alignment it picked up the elevations and created a cross section just fine.
Is there anything I can do besides recreating all the sample lines and cross sections? I'm looking for any other way because I have already labled and put in some extra work on the cross sections and I'm hoping to be able to just recreate what I already did and drop them so it will match the linework I already did.
Solved by tcorey. Go to Solution.
Pick one section view on the screen and then on the ribbon pick Sample More Sources.
That did the trick! Weird, because it already had my surface listed there, but I added it again and now it works. Thanks a ton!
