I have added contours to my surface (the blue lines). For some reason the surface generated contour (the orange line) is jumping across the contours I've added. I'm sure there is a setting or something that I'm missing. Please see attached screenshots.
Thank you!
Desirea
Civil 3d 2014
Solved by neilyj666. Go to Solution.
neilyj (No connection with Autodesk other than using the products in the real world)
It looks like I'm still having some trouble with this. I'm attaching the file with the trouble areas circled in red. I would appreciate any help I can get. Not sure why this is happening.
Thanks.
I tried it with just the blue contours and reduced the supplementing and weeding factors and it looks ok to me....
Sorry, I didn't notice the attachment.
Unfortunately, the engineer didn't provide much for us to use other than a couple of spots and contours.
