I've got a volume surface that I'm trying to analyze in C3D 2009. I need to get elevation-2d area tables, basically the standard ranged elevation table. That's easy enough to do, but in order to use the data, I need to break the surface down into a set of gridded areas, each with its own ranged table. I have attempted to do this using parcels, but the only thing I can get is a single cut/fill/net value for each parcel, and I need to have ranges of elevations for each parcel. I have approximately 50 parcels to analyze, so I'm really trying to avoid using multiple volume surfaces as this will overload CAD. The attached table is what I'm looking for, but I need to analyze 50 subareas of my main, large surface. Have any of you dealt with this scenario before, and what solution did you come up with? If not, anyone have any suggestions on a workaround?
