Civil 3D Forum
Surface Analysis and transparency
3 REPLIES 3
sfore
359 Views, 3 Replies
It appears color transparency for surface analysis is now broke in 2013.  It used to work in 2011 because I use to bring in Lidar data and run elevation analysis over top of aerial photos.  I did a few quick searchs and saw where other folks have mentioned it.  I never found any type of resolution.  Is Autodesk aware and are they working on this?
This issue reminds me of the Point Cloud issue with Lidar data right after 2013 came out.  It worked in 2011 just fine and then 2013 they broke it.  After calls to autodesk support and thread exchanges plus several months of waiting, service pack 2 for 2013 fixed the lidar classification issue.
3 REPLIES 3
neilyj666
in reply to: sfore
Not sure it was ever fixed in 2013; I'm on 2014 now and it works (I think; never tried since installing SP1....)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
ceethreedee.com
in reply to: neilyj666
****... I am on 2013 and its definately broken...
Need to move to 2014...!
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
autoMick
in reply to: ceethreedee.com
It was never fixed in 2013 (and AutoDesk made it clear to me that they weren't going to bother until 2014 when I raised a support request). The only real option was to duplicate your surface, then explode one of them. Transparency would work on the exploded version. OK if you're not constantly changing your surface analysis, etc. but a right pain in the ar$% if you are.
Civil3d user in Australia since 2012.
Rail Community
